The Projects Continue, I Have A Wheel Pedestal (meriman Yacht Specialties)on My Hunter 31.5 And There Is A 4 Inch Wheel Welded To A Threaded Rod Which Acts As The Brake For The Steering Wheel When You Turn It Clockwise It Actuates Something In The Pedestal That Keeps The Wheel From Turning. Well It Seems There Was A Hard Plastic Sleeve (grommet) That Fits Into The Hole On The Starboard Side Of The Pedestal. Where This Rod Threads Into And I Am Not Sure If That Plastic Or Nylon Grommet Was Threaded Because It Had Deteriorated And When I Went To Screw The Brake Rod And Wheel Into The Hole It Broke In Several Pieces. The Question Is This Suppose To Work Is The Nylon Piece A Grommet And Somewhere Inside There Is Something Threaded This Screws Into Or ??? The Boat Was Missing This Rod With The Round Wheel On The End And The One On My Hunter 34 Is Different Larger Threads And Has Some Mechanism Inside That The Piece Screws Into. I Picked This One Up From A Salvage Hunter Model Boat 28.5 2005 Could It Be The Wrong Size?
