Hunter 306 sailboat needs a rubber plug for the gear shift/throttle
Jun 4, 2007
5
- - Chocowinity, NC
The gear shift/throttle is mounted on a Lewmar pedestal. The missing rubber plug prevents a pin from falling out. I must depress the pin to shift into neutral, forward, or backwards. Where can I get a replacement plug?
Oct 29, 2005
2,366
The rubber cap comes of easily, hence I put some sealant to make it stick but can be remove if required.
Ken Y
