Skylights
There are two pieces (inner and outer) on each of the two skylights. I don't know where they are available, but probably from Hunter. Depending on what you actually need though, it looks as though they wouldn't be too difficult to make, if you can't find them anywhere. I think the outer one is about 1/2 inch dark Lexan while the inner is about 1/8" Wrinkle finished opaque/clear plastic. Make a pattern, cut to size, drill, and mount. Mine are fine, but I have always had a hard time getting a nice bead on the flexible joint (outer deck side). I guess I just need more practice. Good luck.
