Prop Size
The older H30 max prop size is 13 inches ( unless you want to start changing all the prop shaft and mounting angles ). My limited understanding is that running a 28 - 35HP engine on a 13inch prop is futile. You really don't get the the full HP from the engine because the prop is too small. Also, you will have a hard time getting a corrrectly pitched prop.I did the calcs a while back, and the HP required for "theoretical" hullspeed ( 6.7 ) on the H30 is 14hp. By calculation, to get about 5 knots (no outside forces ) requires only about 4 HP. Also ( just by calculation ), with a 20 knot headwind, you need about 15 HP to go 5 knots.To be prudent, you should add 10% to 20% to these HP estimate to account for HP loss to alternators and water pumps and engine maybe not running tip top all the time. So 15HP to 18HP is about right depending how much wind you buck, and how fast you need to go.To add 100% to 150% more than that for extra kick to battle headwind, you must be planning to sail into hurricane force winds and still keep hull speed. I have seen 2 different H30s on yachtworld.com with 3gm30s though....
