battery selector
The battery selector on the 290 is a simple battery 1, battery 2 and either both or all. After reading the posts, there is some explanation. On the back of the selector, you will see three posts marked 1, 2 and common. The positive leads from your batteries go to the posts 1 and 2 if you have a dual battery system. The common is for your positive line leading to the the DC panel master on/on off switch, positive line to the engine. On the 290 and above, you have a source (generator or alternator) that charges your batteries while the engine is running. If you have the AC battery charger, then in essence you have two charging capabilities. When the boats leave Hunter, both wires for charging are usally connected to the #1 post as they only offer a single battery install only on some models. You have to be sure if the original dealer placed the other wire to the #2 post in order to charge both batteries.Sometimes, I have known the selector to simply go bad, but in this case, I would suggest the wiring hook up on the back of the selector which is probably the source of the problem on the original post.For your alls information, it is not good to switch the battery selector while the engine is running. You could screw up the alternator on the engine. Most of the selectors have a quick field disconnect that helps to protect the alternator on the engine when mistakenly switching the battery selector with the engine runniing. If replacing a battery selector on a two or more battery system, make sure you get the one that has the quick field quick dissconnect. Also, you will find the newer Hunters using yellow wiring for the DC negitive which is the new code.Crazy Dave Condon
