Hunter 29.5 sanitary hoses
Dec 14, 2009
37
Hunter 29.5 Buffalo
my 1994 29.5 is starting to stink and I want to try changing the hose from the head to the holding tank. Anyone who has done this, are the hose connections at the holding tank accessable? I'm going to try to get to the boat this weekend to look things over.
Regards
Dec 14, 2009
37
Hunter 29.5 Buffalo
If anyone else has a 29.5 and needs to know, on the aft side of the aft birth, there are 2 vertical wood trim pieces that when removed, allow you to remove the center panel. This gives you full access to the holding tank and the fuel tank.
Regards
