A
Al Workman
1) I am the third owner of my boat - one item is not clear in the boat documentation which was passed on to me. There are two manual pumps in the aft quarter lockers of the 29.5. On the starboard side is a waste overboard pump which is accessed from within the battery locker. On the port side is another pump which is accessed from the outside, below the transom seat. It appears to be a manual bilge pump. Is this correct and where does it draw from as I do not see the end of the line in the bilge?2) Is there a chemical drain opener suitable for the flexible corrugated drain pipes used by Hunter?3) Are there any concerns/issues in installing a guage to indicate the amount of material in the holding tank?
