Hunter 29.5 leaks between hull and deck mount or through scepter?
Derk
Nov 20, 2020
2
Hunter 29.5 Noordschans
My Hunter 29.5 leaks a littlebit inside the galley, above the backrest.
On the innerside of the hull. . (At the height of the rubber bumper)
I wonder if it comes though the scepters or is it a leakage between the hull and deck mount?
Has somebody experience with a repair of this?
Jan 7, 2011
5,880
Oday 322 East Chicago, IN
Water can take some interesting routes.
Are there any port lights above where the leak appears? This is usually a common leak point.
As are stanchions and other perforations in the deck. These would leak when it is raining or when waves are crashing over the boat.
It could be the joint, and I think that would be most evident when heeled over (hard)…is that when you notice the leak?
Greg
Derk
Nov 20, 2020
2
Hi Greg, thank you for your suggestions. I've bought an endoscope. I think i'm gonna make at the end of this week some pictures. I'm gonna post them here (if possible) i hope you want to look at it. Thanks Derk
Likes: Tally Ho
