Hunter 28 stuffing box ...
eliems
Apr 26, 2011
102
Hunter H28 Port Moody
Taking her out of the water next week to do bottom paint and zinc etc and I have a question. On the way home from Broughton I noticed water sloshing up against the ridge of the motor compartment and traced it to the shaft going through the stuffing box. (After four hours there was 2 cups in a plastic container I put under the shaft exit which seems more than the drip should be). Do you know what the solution is?
Thanks!
Dec 2, 1999
15,184
There should be NO drip when the shaft is NOT turning. When the shaft IS turning you should expect 2-5 drips per minute.
You need to adjust your packing glan or repack it depending on the condition of the packing.
It should be tight enough that the shaft does NOT get hot (only warm) when the shaft is turning.
May 6, 2012
303
Hunter 28.5 Jordan, ON
I'm going to go ahead and suggest that you check the feeling (cold/warm/hot) of the stuffing box rather than shaft.
My stuffing box is rarely warm and never hot. It drips none at rest and 2 drops or so per minute at cruising speed.
I never adjust more than 1 flat (about 1/6 a turn) at a time, and it is usually less fiddling to start loose (leaky) and then tighten (drier). Check, tighten, run 5 minutes, check, tighten, run 5 minutes... until satisfied.
Apr 11, 2010
975
Hunter 38 Whitehall MI
From the sounds of your question I am speculating that you've never tightened the packing nut to changed the packing yourself. If not, ask a friend who has to show you how. It's not difficult bit critical you do it correctly. Too tight and you can overheat and damage the shaft. Too loose and it drips a lot, and not done correctly and the packing nut can back itself off with potentially disastrous results.
The packing is held in place by a nut that compresses it in to the stuffing box. There is a second nut that that tightens up against the first to prevent it from backing itself off.
Jun 16, 2011
173
Catalina 350 Rock hall
Why not go dripless we did on our 28.5 easy and works great no more drips!!!!
Jan 26, 2008
50
Hunter 31- Deale
Thanks!
I agree to start loose and tighten gradually. I suggest if you replace the stuffing material pay a little more and get the "gore-tex" stuffing material.
