Hunter 28.5 Sonar Keel Offset
Jul 10, 2023
1
hunter 28.5 el dorado
On my Hunter 28.5, I recently installed a new Sonar Transducer right next to the original unit and Knot Meter sensor (under the floor just left of the engine) . What is the Keel offset I should program into my new chart plotter?
Depends on your preferences. Some folks want to know the depth from the surface, some want to know the depth below their keel. Best to take the requisite measurements before launch.
Get a good depth measurement at the dock roughly inline with the transducer. Compare that to the reading you have. The difference is the distance between the water surface and the transducer. Adjust the offset so both readings are the same if you want the depth reading from the surface. Basically the same process with depth below the keel, just need to know the draft and do the math.
