Hunter 28.5 Salon Table - Request Pictures, Etc
Aug 1, 2008
10
Hunter 28.5 Ottawa, ON
Good day. As the snow is now starting to disappear off the boat tarp, the first item on my check list is to make a salon table for my Hunter 28.5. (The previous owner removed it.) I am requesting as many pictures and measurements as possible of the entire table (up, down, under, brackets, etc). Many thanks in advance.
Ontario Guy
May 6, 2012
303
Hunter 28.5 Jordan, ON
Hi,
Depending upon where you are in Ontario you might find it more convenient to swing by my boat after I've removed the winter cover and take as many measurements/notes/pictures as you like.
I also have a bimini for which you could do the same (noticed your other thread).
I'm at The Beacon in Jordan. We'd just need to work out the timing.
If not I can certainly take some pics for you.
Aug 1, 2008
10
Hi Nom De Guerre and thank you for that invite. Unfortunately I'm in Ottawa, a distance of 515 km away (according to Google maps) so that may be a bit of a problem. I would very much appreciate pictures (with measurements) of both your table and bimini. Also any problems / concerns you had to overcome in installing your bimini with reference to the lower boom. Again, much obliged and many thanks. (I plan on taking the boat down to Lake Ontario in July if the snow is gone by then lol.)
Ontario Guy
May 6, 2012
303
Sure, sounds good. It will likely be a couple of weeks before I can turn it around.
I'll keep you posted.
