David Smith
My 1988 Hunter 28.5 has a 20 HP Yanmar 2 cylnder diesel motor.It has always vibrated or knocked a little but no really more than a 2 cylnder diesel rock.I knew the prop shaft was bent and corroded so this year I planned to replace it and fit a folding prop. I did this using a Martek Mk III Eliptec Folding Prop. 16" Dia * 10" pitch X 1RH.I renewed the shaft, the stuffing box and the cutlass bearing and all appears to be perfectly aligned.This resulted in an exterme knock and vibration.As a result I hauled the boat and replaced the folding prop with my standard 2 blade prop.Now I have an extreme "knock" at about 800 RPM and at 2800 RPM. I did not have it anywhere near as bad as this before I replaced all the items above. I really can only now run at idle and 2,200 RPMThe engine almost rotataes in a vertical circle on its mounts at these speeds.We can not see anything out of alignment or touching where it should not.Has anybody else had this experience on a Hunter 28.5?Are there any suggestions as to possible cause?Are there any solutions?Any information would be really helpful because right now we are stumped and I do not know whether to returnm the Matec or not.David SmithSmyrna Yacht Club
