Dear readers,
1. The lock nut of my propeller shaft (gland) cannot be moved anymore, even with 2 wrenches. What to do? which wrench to be used and using penetration oil will do good?
2. The dirty water in my Jabsco toilet is coming back in the reservoir after pumping it away. I cleaned (and replaced the rubber plate with circular cut) already without any result.
3. My Kuuma water heater is becoming only a little bit warm, on shore current and on heated coolant of the motor.
WHat to do?
Thanks
Jan van der Klooster, the Netherlands
WHat to do?
Thanks
