Hunter 27' Mast shortened 4 inches
  • Thread starter Kevin Gillespie
  • Start date
K
Kevin Gillespie
Had to shorten the mast by four inches due to it being run over by a tractor during dry dock. Now I have to shorten the front and rear stays but I don't know by how much? Does anyone know how to deal with this?
Mark M Smith
4 Inches?
Not trying to be a smart ass but if you cut 4 inches it seems to me the rigging will be 4 inches too long.
Johnnie Poole
It's a Trigonometry question
4 inches will probably be close, but no cigar! It's actually a trig problem from high school (Graduate school in Alabama!). If you consider the mast as perpendicular to the tack of the headstay and the rear tangs for the aft stays, the problem is to find the difference in the length of the hypoteneuse using the formula HSquared=OppositeSquared+AdjacentSquared. Measure the distance between the base of the mast and the head/back stay attach point. Then run the formula with the current mast length. Run the formula again with mast length plus four inches. If you cut it short, they do make extended length turnbuckle screws for Norseman-type fittings. Good luck. Johnnie, S/V Jazz
E
ed
COverage
Gee, I would contact my insurance co. or the guy's whop ran over your mast. It would be a lot easier than cutting up stays and shrouds..Have'em get you a new spar.
E
ed
another route
I think i would look into adding 4 inches to the bottom. It should not be to hard to get that done.
