We have a new to us 2000 Hunter 260. The trailer is the stock trailer. There are no goal post or any othe rmodifications. We will be keeping the boat in a mast up lot se we will be launch and load each time we use it.
What trailer mods do you recommend to make this process as easy as possible?
My thoughts are as follows:
1. Front and rear goal post. I am thinking about running bumper lines between the two to guide it in on a windy day.
2. The bow roller is only slightly higher than the bracket and seems that it would be easy damage the hull if I was off. Replacing the bow roller with a biiger one.
3. Keel guides to center the boat and assue the keel is on the center rest.
4. Keel has about 1/1 to 1 inch play so I think the cradle boards are positioned properly.
Comments or other ideas.
Thanks
Tim
Thanks
Tim
