Hi,we recently bought a 2003 260, and have lots of questions. We will search the archives first, but will probably ask questions that have been posed and answered on the forum before. Please forgive us.Question one:There is a bend in the mast support crutch. It looks as though this is not a "factory" bend. Is the factory mast crutch straight from end to end?Question two:We are installing a 12 inch Lowrance LRA 1000 radar dome. We have considered the following possible locations, and would appreciate ideas and comments:1. place it on an aluminum pole that inserts where the mast crutch normally goes. The pole will need to be long enough to get the radar dome at least 1 ft above head height to avoid frying the crew. It would also need to be above the level of the boom. Maybe a 10 foot long pole would work. It might need struts to brace it. Would it have to be turned off when the crew goes forward? Does anyone know if there is a distance the radar beam is safe to be in?2. Use the mast crutch, and mount a short pole to extend it higher, then proceed as in 1 above.3. Mount the dome above the foresaty on the mast. This would place about 14 pounds of weight up the mast, and would require a way to disconnect the cable at the base of the mast when trailering. Would it be necessary to remove the dome when trailering? Any good sources for 8 conductor waterproof connectors?I will ask other questions in additional posts to make responses easier.Thanks in advance!
