Conduit to Electrical Panel
I did this on my 2005 H260 last week. I used a tool called RotoZip and cut into the raised portion of the headliner where it goes from horizontal to vertical inside the cabinet in the galley. The conduit runs inside this raised portion and ends right about the stanchion.Once I cut into it and pulled the wires using the line provided, I brought the wires out and ran them inside the liner to the panel area. I needed a straightened coathanger wire to fish the wires. This description probably isn't the best, but I have to emphasize the need to cut into the area where the conduit runs to access the line inside for pulling the wire. The most inconspicuous place is in the cabinet.The conduit is built in, and covered with resin.
