I am replacing the outboard and transome on my boat. The original transome as best I can tell was just a 2 X 6 that others have commented was too close to the cockpit for various reasons. The previous owner put on the a transome with up/down as you see here rebuilt using white oak. (the original broke and sank to the bottom of Green Bay).Here it the question: The new engine is a Nissan 9.8 Hp (Hunter says the boat is rated for up to a 10 HP) but does anyone think the transome extension with the added weight will put too much pressure on the plating or are others working with a similar setup that has faired well. I also went with the 25 inch extra long shaft as the original never really seemed to drop deep enough using the orignal transome.
