Info from Hunter
This morning, I received a reply from Hunter (Greg Emerson) on my question. He indicated that there was only one jib sold for the H26 and its measurements are the same as mine. He also said that it is a 100% jib. This matches the information I received from a sail loft when I recently had it cut for the roller furling system (Something like 1/2 the measurement of the foot x the perpendicular line to the luff).I asked the question because I wanted to know if any of you are using a slightly larger headsail (extra 10%), esp. since the common wisdom appears to suggest we stay away from the 135/150 genoas.On the proficiency issue, there is some interesting information about the Hunter 26 on the Portsmouth Home site. According to their "yardstick", the H26 comes in around "92" - not bad for the non-performance boats in this size range. Rick
