Magic Tilt?
I like the idea of a second axle, but Rob Mitchell has the same rig as me (and you too from the sounds of it) and scrapped the leaf-spring axle for a torsion axle. I don't know what he did with the tires. As I recall he had an outfit in Wyoming mod it for him, but Champion sells kits as well.In '05 I through a weigh station with a 2001 H240, with the Magic Tilt trailer, and measured 3,620 lb. trailer axle weight.At home I measured 370 lb. tongue weight.This was with most of the 4-days worth of supplies in the truck.The 98-pound outboard engine, boom, bimini, tools and electronics were in the boat, and a spare tire was mounted on the trailer.There was no water or gasoline on the boat.Given that the magic-tilt trailer has a 3,420 lb. G.V.W.R., it's overloaded.Springs, tires and axles are inadequate for the real world trailersailor. The only way it works in the factory configuration is to strip the boat of everything before you hit the road.
