Hunter 240 cover
Jan 18, 2018
3
Hunter 240 Hinnom, VA
Does anyone have a source and/or plan for a fairly easy to remove cover for a Hunter 240?
My vessel is so close to an Osprey nest that the birds use the spreaders as a perch and dining table. You can imagine what the deck can look like. Tarping is getting old & not a good look.
Txs
Woodyvv
Nomini Creek, VA
Rats, they have a 260 pattern; no 240. The search goes on. Ospreys return this month!
Woodyvv
Those two boats are so similar, I can’t help but wonder if you took the 260 pattern and reduced it by 7% you would have a pattern for the 240??
Jan 18, 2018
3
I called them & learned they had the 260 pattern. I plan to call them with your suggestion of 7% reduction. My concern is getting the mast struts/supports right.
Thanks for following up.
