Hi,
Newbe question regarding a 2001 hunter 240 water ballast valve gasket. I just purchased the boat and noticed the valve leaks when the boat is up on my lift. It seems when the valve is closed there is a gap on the starboard side between the bottom of the boat and the valve plate. The gasket is very thin spongy rubber. Is this gasket compressed? How thick should it be? The manual just states it is a rubber gasket and shows the valve flush with the boat in the diagram.
Any advice is appreciated.
