Learned quite a lesson in rig tuning this past weekend! Ever since I started sailing my H23 it has demonstrated considerable weatherhelm, to the point where any time I was heeling over more than 5-10 degrees I would have to put considerable effort on the tiller, and actually steer hard toward leeward just to keep from rounding up into the wind. Besides the fatigue from putting so much effort on the tiller, I also was losing considerable speed due to the extra resistance of the rudder in the water, and if the wind would die down suddenly I would turn leeward rather quickly. I mentioned this to another sailor in the marina, Tom, who bought his Catalina 25 in 1978 and has been sailing it ever since, and he commented on how he and some of the other sailors had just been commenting on the rake of my mast, and how I had to be having that problem. He suggested that I shorten my forestay and lengthen my backstays by adjusting my turnbuckles. I set out to do just that last Sunday. After loosening my shrouds and backstay, I went to the anchor locker to tighten my forestay. I was dismayed to find out I did not have a turnbuckle to tighten. A roller furler is installed, and I went off to find Tom to ask his advice.
Tom appraised the situation and quickly came to the conclusion that needed to remove a metal extender that was on the forestay, and install extenders on the split backstay. These amounted to about 1-1/2"of shortening/lengthening. Once I moved everything around and tightened the stays and shrouds, I headed out for the water.
Wow what a difference! The boat handles TOTALLY different when heeled over. Instead of trying to round up, it digs in and accelerates (or continues to heel even more until I adjust the sheets ) I made 7.4 MPH on my garmin that afternoon with my 150 genoa out. I am going to make some fine adjustments this weekend, I may have too little weatherhelm, and possibly some leehelm, but I'll figure that out. I had my daughter (age 11) on the tiller late Sunday and she heeled the boat over a couple of times to where the stanchions were in the water a couple of inches. A little disconcerting, but exciting.
Cheers,
Chris
Cheers,
Chris
