I do not believe this question was answered.I recently purchased a new "to me" H23, that's in pretty good shape except for the cabin sole. The Boat seems to have an issue taking on water and the wood cabin sole has completely fallen apart. As far as the leak is concerned. it seems to be caused by water coming in during heavy rains. I've removed the wooden cabin sole and over a couple of dry days don't see any leakage around the keel bolts. Unfortunately after heavy rains there's a lot of water in the boat. From what I can tell the majority keeps coming in through the weep hole in the last bilge before the forward compartment. I'm pretty sure that's routing water from under the cockpit area forward. Can anyone confirm? also, can anyone give advice on how to stop this or slow the rainwater leakage down? I'm considering putting a bilge pump back there, but am hesitant about drilling another through-hull. Thoughts? As for my ruined wood, any idea where I can replace it? Is there perhaps a good looking material that would be more resilient to water? I appreciate any help you all can offer me! Dan
What crazy Dave said. Should be the quickest way to find the leak.Dan; Here is the best way to find topside leaks which will require another person and a few items to include plastic, tape and a bucket or good soapy water with brush and garden hose. Forgot the leaf blower. You want to pressurize the cabin to force air out which is the key as where air escapes, water will penetrate. Close off opening ports and tape around the where it closes. This includes the forward hatch. Then take a large piece of plastic taping it to the entire companionway. Put a slit in it just big enough to insert a leaf blower and tape around it. Then start it and let the other person brush all fittings, rub rail and so on and where you see air bubbles coming out, then that is a source of leakage. Usually the wire chain plates, anchor well, screw/bolt attachment areas of lockers and so on were culprits. Hope this helps.
