Galley Info
David,You haven't gotten a lot of response on your galley question. The galley was on the port side and set on port side bunk. I had a sink, hand pump, and a single burner Origo alcohol stove. There was a 5 gallon water poly water jug in the lazarette for fresh water storage.The galley slid under the port side cockpit for storage. The sink, pump, and stove are all available via marine stores. I'll take pictures and dimensions for you after May 1 if you want them. [you'll have to give me your e-mail address.]Regards,Jerry
