Hunter 23 cockpit drain
131
Hunter 23 WIll be at a Navy base
Today was one of those days that one would like to sell a boat. I had not been to the boat is about 2 weeks. It sits on land on the trailer and it is 500 feet to put it in the water. However, it sits under trees, the stuff from the trees falls in the cockpit and when it rains then the drain gets clogged and the cockpit fills up. Anyone have a good idea to keep the drain opened. One solution is to cover the cockpit. However that is difficult as how the boat sits. It was so bad my gas tank was floating and it had 2 gallons of gas in it.
Jul 26, 2010
140
Hunter 23 South Haven, MI
Lowe's sells these small round metal downspout strainers for your gutter. They work really good to block tree droppings from clogging up the downspout. I wonder if you could jam one in the cockpit drain. I put them in my gutters and they expand and contract so you can jam them in a pretty small hole. It'd only cost $2 to find out though. :)
Amerimax 3" Aluminum Downspout Strainer
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I have the exact same issue, when it has been sitting in storage. I have no proven solution, but this Fall after I haul, I intend to try putting some screening like maybe chicken wire over the rectangular trough in which the scupper sits. The surface of the wire screen could get totally covered of course, but it would take a lot more leaves than the few that can clog that small drain cover. I will also make sure the cover is installed better (I just bought the boat this past May; prev owner had paid the yard to shrink wrap it, but that left opening at transom).
May 9, 2010
131
What kind of cover? Do you drop the mast?
I had the same thought. I bought 3 pieces of hardware cloth. It is like chicken wire, but it is comes in various size square holes. I bought I piece 1/4 in hole, a piece 1/8in. hole and a piece of metal screen wire. I am going to make a sandwich out of it with the screen wire in the middle. You only need a 12 in x 24in piece. It is a little wide so I am going to bend the the sides and back so it is a snug fit. May need to stick a brick or something on the front side. My intent is to leave it in during the season as well as that is when I am really having the problem. When I went to go out just take it out and when you come back put it back. I am not sure this is full proof but it as attempt. The boat was so full of water last time that the front jack wheel was off the ground and that is with the rear having block under it.
Apr 27, 2010
1,279
The previous owner is the one who did the most recent winter store.
He did drop the mast (it was on the transom crutch and the bow pulpit "crutch"), and he paid the yard to do shrink wrap. They put in a few 2X4 frame pieces to tent the shrink wrap.
I'll obviously drop the mast (well, I guess it isn't so obvious - to get the boat from the ramp to the yard across the street, there are power lines that make you drop it), but I'll remove the furled jib, unlike what he did. I'll use a cover instead of shrink, and will try to rig some sort of PVC pipe frames to support the cover - Lake Wallenpaupack area gets a good amount of snow; in fact, the storage yard is more or less at the base of a ski area.
May 9, 2010
131
I had a San Juan and I kept the mast up and did the best I could to cover it. On the cockpit I bought a piece of 3 in cheap pvc and put it from the hatch and hung it over the stern then draped and bungie chorded a good tarp. I used 2 tarps one for the cockpit and the other over lapped and covered the entire bow. I am a little afraid to raise and lower the mast. I have looked and looked at how to do it. I am just not comfortable. I do not have to drop mine as where I keep it is 300 feet from the ramp and no wires. There is probably 2 dozen boats that do the same thing. I guess I am lucky. If you have any good ideas about dropping the mast, I am opened to all. I had it stepped at a marina that used a small crane and was $300 bucks to raise the mast and tune it.
Apr 27, 2010
1,279
You now have an H23? You say you had a San Juan, so I am describing this for the Hunter 23.
It is not that hard to step and raise the mast, and there are various posts and videos you can find that show how to do it. Do you have the mast crutch that goes into the rudder pintles? If so, the general idea is:
1. put the crutch in the pintles and raise it as high as it can go (if it is adjustable height)
2. loosen all the stay turnbuckles as far as you can - just make sure it isn't so far as to not support the mast (which would be almost impossible, I think, unless you removed one completely)
3. rig a line with a pair of double-blocks, like maybe the main sheet, from the bottom of the jib halyard to one of the fittings on the bow, like the pin at the front end of the anchor well, on the deck. Extend the halyard so it is long enough to reach near the front chainplate, and cleat it at base of mast. You may have to buy a pair of blocks and some line. I run the loose end of this "lifting" line through one of the jib sheet blocks to the jib winch and cleat.
4. Pull the line with the double blocks as short as you can make it (blocks as close as possible to each other), and fix end to the jib cleat in cockpit. Tighten the jib halyard with the winch to slacken the front stay (or roller reefing rig, if you have it). I have roller reefing, and found it easier to remove the sail before doing this, though the prev owner did not.
5. remove the front stay toggle pin, at chainplate
6. use the "lifting" line to gradually lower the mast - the double block arrangement gives you the mechanical advantage to hold it. You will need maybe two or three people to help steady the mast side-to-side as it lowers, since the side stays no longer provide any support (and get looser as you lower it).
7. once it is lowered into the crutch, remove the mast pin at base of mast. Note that it may not be possible to get it all the way into the crutch without the mast hitting the roof of the cabin, if crutch is too short. Make sure the helpers can hold it while someone removes the pin - it is heavy.
8. carry base of mast forward so it is in "crutch" support on bow pulpit, and so stern crutch supports top of mast. Remove and secure stays.
Various people have rigged gin poles or other supports to help increase the angle of the lines, as did the PO of my boat. He made an aluminum bracket that wraps around base of mast, and extends about 6 inches in front of the mast (basically, a U shaped piece of aluminum sheet that is maybe 1/8 inch thick - must have been hard to bend). He drilled two holes through bracket and mast (which I don't like) and bolted bracket to mast. He used a pretty robust aluminum pipe (say, 2-3 inch diam) bolted with two bolts to bracket, so it sticks straight forward (that is, horizontal) when mast is raised. The pipe is sized in length to be about 3 or 4 inches short of the forward stay. The front end of pipe has an eye bolt vertically through it with eyes on either side. The halyard attaches to top eye, and the lifting rig line to lower eye. This way, the angle of the lifting line is much higher and easier to manage. I have seen a video on You tube showing the whole process, and this author used two pipes (metal electrical conduit) forming a inverted V, with the two lower ends of the V atatched to the forward lifeline stanchion bases, and the upper tip of the V supporting the halyard end and lifting line respectively.
On the other hand, if you can safely tow it to the yard and not have to remove it, why bother? While tuning the rig when you launch and re-raise the mas isn't all that hard (well, I have only done it once, as a new owner, and am not sure it is actually "perfect") it does take some time. If you don't race, and I don't, "good enough" tuning seems to be the objective, and mine seems to sail OK - not too much weather helm, etc.
The tuning process I used (and don't take this as gospel from an expert):
1. lift a long tape measure all the way up halyard - I bought a cheap 100ft reel tape at Harbor Freight tools for like $7. Attach loop at end of tape to halyard shackle, and attach safety line to shackle in case tape measure breaks.
2. If you can (I did not, as I was forced to put boat in water before I could) use front stay to adjust mast position front to back so mast has about 2% rake rearwards. Use a line frm top of mast and weight (like plumb bob) to see where line "points to" on boom, and it should be about 2% of distance from boom to where line attaches to mast. E.g., if that length is 30 ft, distance from mast to point of weight would be 2% times 30 ft).
2. adjust upper side stay turnbuckles so mast is vertical side-to-side, by measuring length to each side chainplate until about equal. Tighten these turnbuckles so they "feel tight", and mast upper bends slightly aft. As you tighten, the swept spreaders push the mast forward, so top bends back. As you tighten, make sure you turn both turnbuckles equal turns, and recheck mast centering when done, using tape measure.
3. tighten inner side stays so mast is straight by looking up the mast main sail groove. I fould it fairly easy to see when it is pretty straight, and as you tighten each side the inner stays pull the center part of the mast side to side.
4. tighten rear stay turnbuckles
Search for other threads on tuning - there are a lot here, from folks with much more experience than I. One season of raising and tuning does not an expert make.
May 9, 2010
131
I do not have a gin pole or anything else. I used to do the San Juan with a 2x6 with a groove. I would release the roller furling and slowly lay it into the 2x6 that someone held. This one is just to tall to pull that game. The San Juan mast was like 9 feet shorter and a 1/3 the diameter. Do you have any ideas of the sight of the videos I have looked and can find anything.
Thanks for your help!!!!
May 9, 2010
131
I did the 2 pieces of the hardware cloth like I said. I then put a brick on it to hold it flat. It worked perfect there was a little water at the bottom of the v drain. I made an adjustment and hope that will finish the issue. I did not have half a cockpit full of water. I measured and made it fir to the exact edges and then I wired the 2 together using a very small wire.
Sep 11, 2010
33
Hunter 23 Hudson
I went to homedepot n bought a 6x10 tarp. Weight the corners, and put it over the boom. Most of my issues with leaves n rain were eliminated. It's easy to remove n put on. But, it will blow or move in high winds.
