I know this has been covered in one place or another, but I have not found the answers I need.
I have a bit of water coming down the electrical lines that run to the mast light that then runs down the compression post. It is not a bad leak just enough to be an issue. Then there seems to be some water getting in from the companion way hatch. This one is more tricky as I am not sure how it is getting in or how to fix it. I have a tarp over the cabin on the deck for now.
I have no experience tracking down leaks on boats and methods of correcting them. That is really what I am looking for. It seems the water comes in somehow and runs to the bottom of the stair way then trickles down to the first floor board where it pools where the first set of keel bolts are. I was able to see the trail as it was colored with teak oil as the previous owner recently oiled the teak.
I probably wont be able to get the boat out of the water until the fall. I am looking to correct anythign I can at the dock then properly fix them this fall when it is on hard.
Thanks,
Thanks,
