Recently bought a H 23 with Z-spar boom. The previous owner had rigged the outhaul to not use the internal pulley system. I want to restore this so I can trim the sail properly. Can anyone tell me how it is to be rigged? The boom seems to be able to accomidate the outhaul plus two reefing lines. Inside, it only has on block attached to the aft end of the boom inside. There is another pulley which can be rigged so the line runs the length of the boom three times with a wire on the other side of the pulley to use for the outhaul. How do you hook up the reefing lines internally? are they hooked to this single pulley system somehow as there's only one block inside on the aft end to hook on to.
Thanks for any help for how to rig the outhaul in general on this boom.
Hank
Hank
