Hunter 23.5, Tiller, metal or wood & Around Alone
H
Hayden Jones
My aluminum tiller wobbles after years of wear and tear. The bolt holding it to the rudder housing has expaded the hoile through the tiller producing a wobble in the tiller. I could drill out the holes and put a spacer of sort in the hole but I fear that will only be a stop gap measure. I'm considering a change to a nice laminated wood tiller ( it has nmore class than metal) but am concerned about fit. Has anyone replaced the metal tiller with wood? How'd it work? Can you stil use the cockpit table while underway? As always, thanks in advance. Side bar: Got a chance to solo the boat last week while on vacation ( this is my first year with this boat) What a thrill. I am planning on retiring in 1 year, 4 months and 12 days ( but who's counting). That following spring (April or May, 2004) I plan on circumnavigation the DelMarVa pennisula ( My version of around alone) . I will sail out of the inlett at Ocean City MD, north through the Delaware bay and up the Delaware river to the C&D canal. I'll motor the 12 to 15 miles accross the canal and then sail down the Chesapeake to the Bya entrance. Then it's north up the coast to Chincoteaque, behind Asseteaque Island and home to OC. Any input will be appreciated and USED>>>>>>>>>>>>>>
Steven Gautney
Get a new metal tiller from Hunter . . .
Several on the forum have described the wear that you have experienced. If you have time and a good machine shop available you can get a custom bolt/spacer or have the area welded. Last I talked to the folks at Hunter they would send a new one for about $70.00. Which in my book saved a lot of hassel time that I would rather spend sailing . . .
A
Alberto
a wooden insert is a cheap cure
I had the same problem and fixed it inserting a 20 cm of wooden cylinder (a piece of the rod commonly used for home window curtains). The cylinder is fixed to the aluminum tiller tubing by two small rivets. Then a thru hole is drilled exactly the diameter and in the position of the thru bolt. It takes less than an hour work and some € for the wood. With water the wood will grow up and make a fixed body with the tiller. Hope this helps Bye Alberto Canta che ti passa Rome Italy
Sean Coerse
Del Marva
I have thought about doing the Delmarva in my 1998 H240. So far the longest trip I have taken is a 4 day sail from Norfolk up the bay to the Potomac and then up to DC. Ever since I did a delivery on my Dads Sabre 34 from Ct. to Md. I've wanted to get back out in the ocean for something other than a day sail. Enjoy retirement some of us have a lot longer to go.
Rick Webb
Same Experience
I took mine to a machine shop who welded in a piece of aluminum to make the hole solid and then drilled the hole back in. the other thing to do is replace the bolt that holds the tiller with a longer one so that the threads are not eating away at the tiller all of the time. I put a wing nut on the end of mine so that I can remove the tiller at anchor or in the slip. I also added a peice of teak with pintals and gudgeons to go between the rudder and the peice of teak that is the motor mount. with that the tiller does not take all of the beating from holding the rudder in position when not in use. Check the archives and the photo forum there are better descriptions on this there. Let me know if you have questions about how I did mine.
