Hunter 23.5 Lists to Starboard
60
Hunter 306 Bluewater Bay Marina (Niceville, FL)
Hey folks, hope everyone is enjoying the Summer...here in the DC/Potomac area we just had our own personal little Katrina last week! I have had my 1993 Hunter 23.5 for three seasons now...this time when I put Bon Temps in the water and filled the water ballast tank, I ended up with about a 5 degree (just noticeable) list to starboard as the boat sits in the water. I researched and found out that failing to fill the ballast tank is easy to do, so yesterday I opened the valve and plug again (for several hours) - no change. Any idea what might be happening? I have the battery under starboard settee, but that's same as in previous years. Am using the PortaPotti now, but it's a gallon or less, and bsically centerline. No water under anywhere where I can see...nothing of any significant weight on that side of the boat that would cause such a list. I have fantasies that the scum and hydrilla that infests the Potomac is in my tank and some "sludge monster" is growing in there and displacing water. I think I will put a gallon or so of bleach in the tank, sail a day to agitate it, then get my trailer, pull the boat, empty ballast, and refloat and refill. I don't know if that will make any difference...doesn't seem like it should, but I simply have no other ideas. Anyone out there have suggestions...or similar experience? Thanks!!!
Feb 27, 2004
155
SunTracker 18 DLX PartyBarge Hoover Reservoir - Columbus OH
I'm pretty sure that the list is common...
to that era Hunters. My '93 19 has it too. With the battery and the outboard both to starboard the weight is off. Maybe you just didn't notice it before this? I only notice when the boat is in the slip.
Drew
Mine too
I've a 240 - Outboard and battery on same side of boat is no doubt the culprit. I've moved gear around to compensate and have pretty much eliminated the list. On the ballast tank issue - assuming yours is like mine, there is a gasket that sits on the top side of the tank cover - the round metal piece at the bottom of the rod you unscrew to open it up. That gasket creates a seal when you close the tank again. Here's the deal with mine: the gasket "floats" - it is not affixed to the tank cover - it can move up on its own and effectively close off the opening while the tank is filling up. So, if you've got a "floating" gasket, get some adhesive underneath it to hold it down. I was also taught when I bought the boat to "top off" the ballast tank with a hose. With that advice, I've had no issues in the past three years. Hope this helps - good luck.
Jun 2, 2004
3,670
Moved My Batteries
I have two batteries in the locker under the V berth sits level now
