Hunter 23.5 Gib Halyard Replacement/Issue
mgiraz
Jun 15, 2016
9
Hunter 23.5 Clovis, CA
Replaced main halyard with no problem. Gib halyard has come to a halt. The wheel at the mast entrance is half gone. The left side does not exist.
To replace I have to drill out the rivets that hold the plastic molding around the halyard mast entrance slot. Once I remove that, what's next? How is that pulley wheel installed? What do I need to order for it's replacemen?
-na -NA Anywhere USA
For future reference US Spars is identical to Z Spar owned by the same owners but under a different name in the US. Forum store can also get the parts
Beneteau 323 Annapolis MD
If it is like mine, The pin that goes through the mast on the jib sheave must be driven out. One end of it probably is a bit of a spline to anchor into the mast. You might tell upon close inspection which end it is. Find the right end, then drive it out from the other end. Be sure to catch it !
