Hunter 23' 1985 model?
L
Lou
I bought a used Hunter 23' sailboat and was told it was built in 1985. I wanted to see if I could find an owner's manual for it. I clicked on the 23' model on this site and it states built 1987 and after... The Hull ID for my boat lists a certification date of 1985. Is it same specs as 1987 model? I'm renting a slip and they want to know L.O.A., beam, draft, etc. It has a fixed keel. Thx, Lou
Sep 8, 2006
116
Hunter 23 Camp Lejeune, NC
Its a typo
Yes its the same, 85 was the first year they made them. Not much different in the years. My owners manual doesnt say much. I think I find more information on here then in it! Good luck, happy sailing!
Sep 8, 2006
116
Specs
LOA23' 3 in LWL19' 7 in Beam8' Draft2' 6 in (with rudder up) Displacement2450 lbs Ballast800 lbs Sail Area 235.5 sq ft Mast Height 33' Water Capacity 6 gal Fuel Capacity NA Aux. Power OB Hull Speed 5.9 I 26' J 8'6 in P 25' 8 in E 9'9 in Capsize Ratio 2.37 Disp. Length RatioT Keel Material cast iron
Feb 6, 2006
249
Hunter 23 Bay Shore, LI, NY
Here's a link to the full manual
http://www.ayesail.net/sailing/Hunter/HunterManual/TableContents.html
