Seth
Friends - I have a '81 H22. My boat was cribbed this winter on railroad ties at my marina. The marina placed a couple pieces of lumber under the front tie to angle my bow up. The lumber was not the width of the hull and did not extend to the sides of the boat. The pressure of the boat resting on the lumber had the effect of depressing the hull 2-3 inches. The result was a crack in the hull that now needs repair. Additionally, I found huge blisters on the hull under the bilge this spring; apparently, water in my bilge worked its way OUT through the glass. Everyone in the yard has remarked how thin the glass on the hull is....it must be no more than 1/8" thick! Do all H22's suffer from this same design issue? Anyone else have similar issues?..Seth
