I have just aquired a 07 Hunter 216. The hull, rig, and lines are in very good shape. While the sails are pretty good, I have been thinking I would like to replace them.
I saw the new Hunter 22 online. It has a very nice squared off main with multiple battens, and a new jib to match. It looks to be a higher performance set than my current suit.
Does anyone know if that suit will fit on a 216. The mast heights are within a few inches of each other. The hulls and keel appear to be the same design in a new material, the rudder is mounted farther aft on the 22'.
I can't find the new 22' sails dimensions online to help solve this problem.
The newer suit are 41 square feet larger (293 vice 252). It appears this is from a slightly larger jib overlap, and considerably more sail in the upper regions of the main due to the battens and squared off top. I don't think this would press the boat to much though.
Thoughts, and if anyone has tried a higher performance set of sails on this hull.
