My 216 Rudder Assembly is beginning to come detached from the deck mounting. The port side is lifting up ~1/4" inch with any weather helm. The screws on that side are no longer holding and tightening them has no effect.
My assumption would be to remove and clean up the existing caulk, fill in the old holes, and drill new ones to ensure proper mounting. I do not have any schematics for the rudder assembly so I suspect it is simply dropped in and then mounted from the topside.
Has anyone had to rebed the rudder assembly on a 216?
