Hunter 216 Mast Plate Qt: where to position the pin & use of mast wedge
Jun 19, 2007
2
- - Peconic Bay Southampton NY
It is not clear to me with the Hunter 216 mast plate where the pin should be inserted since there are 3 options... I have seen some opinions but not sure what is best... as well as I seen some discussions on the use of the wedge when sailing... my dealer only talked about the use of the wedge when rigging the boat in order to keep the mast stable when doing so... would love to know what is best...
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
I always pinned mine to the rear-most hole in the mast step plate. Just confirmed this from the owner's manual, a copy of which is posted in this really helpful link on this very site: https://hunter.sailboatowners.com/dl/downloads.php?task=model&mid=68&model=216
I sailed it for years without a mast wedge. I added one in the last year, but don't think it matters at all for sail trim. It does eliminate the noise and creaks from the mast pumping in the waves, which is a plus. It is somewhat of a pain to push the block in place when there is tension, so I suggest you not tension any rigging until that is done.
Sep 10, 2017
3
Hunter 216 Little Pine Tree Harbour
I also have been pinning the mast to the most aft hole in the base plate. This year for some reason the mast seems to be too far aft in the opening and is about 1.25" away from the forward edge of the opening. The two pins in the hatch cover do not engage with the holes in the cuddy and the hatch cover is not retained and blows off by the wind when docked. Needless to say I am getting a lot of rain water into the boat. I was thinking to move the mast forward one hole on the base plate to try and correct the problem. Any opinions or suggestions?
Jul 12, 2011
1,165
The restraining pin that goes laterally across the partners opening should keep the mast well forward of the opening hatch. Is that missing on your boat? In addition, there is a chock support that engages with that pin and acts like wedges on larger boats to give a bit of pre-bend to the mast so it does not pump in the waves. It's actually available from this site: http://shop.hunterowners.com/hp/part.php?m=216&c=6&p=54671
I suggest if you mast is out of place, check the tuning guide, available on-line, with a Loos gauge. As far a rain water, I used to wrap a garbage bag around the mast and tape it to mast and deck with duck tape, prior to putting on the canvas snap cover. It wasn't elegant, but you could not see it after the canvas was in place.
-na -NA Anywhere USA
Take a photo and post. I clicked on the site forum store and got a message about deciding the prescense of cookies. Cookies is the last thing should not be here and Dave Groshong advise owner to take that off
Sep 10, 2017
3
There is no pin going across the opening on my boat, can you send me a picture of what that looks like.
Jul 12, 2011
1,165
Sorry Dutchy, I sold that boat a couple years ago, but perhaps another owner could help. The un-threaded pin was about 6-inches long, and passed between two eye-fittings near the back of the U-shaped opening, well under the hatch when it was closed.
The manual also does not show it, but only says "Once the mast is vertical, pin it into place." on page 11. I found the link, in case you need more reference materials: https://sbo.sailboatowners.com/downloads/Hunter_216_66592581.pdf
There's a whole section on this site, for your future needs (such as when the hydraulic ram for your keel stops working): https://hunter.sailboatowners.com/dl/downloads.php?task=model&mid=68&model=216
