hunter 216 hull repair
Jul 14, 2013
4
oday mariner 19 wpsa
I have read that the hunter 216 plastic hull can crack. They say it is cold weather related. What is the repair process. The only thing I have read was it wasn't hard to do and well worth it. Any info would be greatly appreciatiated.
Mar 13, 2014
2
Hunter 216 Cape Royal Marnia Lake Livingston
My cockpit has cracks developing in the seating area. Some so deep that the material underneath can be seen.
Also the cockpit flooring is separating from whatever it adhered too. Has the bubble feel to it when walked on.
Help
Mar 20, 2004
1,746
the official acp crack repair manual is in the archive downloads; go to "search" and search on acp crack repair to find it
-na -NA Anywhere USA
Breaknwind;
It would be helpful if you posted pictures as Chuckwayne and I can help you. The old saying a picture is worth a thousand words. What ever you do first is keep that crack from spreading or elongating out. Simply drill a 1/8 inch hole at each end.
Mar 20, 2004
1,746
Crazy Dave is right! Once you put a clean hole at the end of the crack it won't continue to grow - then you can plan and prep your repair
