Re: Fuel Storage
Lee, are you talking about the gas "can" for the outboard or the fuel tank for the outboard? Regardless, there are a few things that may help...
I agree stabilizer is a must especially for these small horsepower outboards. The 4 stroke seem to be highly tempermental and sensitive to any inconsistencies in the fuel.
The way I understand it, the high ethanol content in the fuel has increased the fuel's propensity to attract moisture. Hence, attracting condensation - water condensating into the fuel. Water in the fuel is a bad thing. This causes really bizarre behavior in the performance of the engine. Sometimes everything is fine, other times you can't even start the motor.
So...based on this notion, there are a few things listed below that deter the engine problems:
1. Keep the fuel can in a controlled environment. I never store fuel with the boat more than 1 or 2 nights at the dock. I always bring this to a controlled environment. During the summer months the dewpoint is increased so the dips in high temps vs low temps is minimized. End result is condensation - if the fuel is out by the dock or even on the boat there is a greater chance for water condensation inside the can that you will pour into your motor.
2. I always top off the fuel in the motor's tank upon returning to dock. This has to do with #1. The way I figure it, if I minimize the space where water condensation can build up inside the motor fuel tank, then it will minimize the possibility of water buildup mixing with the fuel. The same applies if you are using a remote tank.
3. Treat with stabilizer. Enough said. The gvt prescribed ethanol increase in fuel has added some additional variables. Any fuel for a boat motor needs stabilizer or ethanol treatement of some sort. Diesel is another subject...
4. When not in use...Ensure the motor fuel line is always closed. Ensure the motor vent valve is closed. Carb based motors are very sensitive with changes in position and atomosphere. Restricting any unintended access through the vent or fuel line minimizes your chance for engine problems and restricts the introduction of water or condensation.
5. Movement and transport of the motor...Always transport the motor tiller side down - double check your manufacturer's recommendation...
HTH...
Paul.
