216 cuddy
It was a winter day when I checked out the 216. The boat I climbed into did not have a mast boot installed and it was wet inside, so I did not spend a lot of time in it. The cabin is completely open to the transom. It has a molded edge on which to place the floor for the v-berth. It appears that the v-birth length will be short 5 to 6 feet. I am not sure if I will install a floor or just go with some thick foam camping mattresses for a place to rest on. It seems to have good sitting headroom. With the ACP hull it is foam lined and the hull should be insulated against the cold. I think the grandkids will have a great time playing in the cuddy when they get tired and bored with the sailing. The amount of storage below is huge and with the ability to put it on a beach I may go with the use of a tent. As you can gather I am waiting to get mine out. It sure does look like a fun boat. I would encourage you to go find one and take a look. It was not the boat I wanted until I went and gave it an inspection.
