hunter 19 weight
Tom C
Hi everybody. I am considering buying a Hunter 19 and I need to know the weight of the boat and trailer combined. My car has a 2000 pound towing weight limit. Thanks!
Feb 27, 2004
155
SunTracker 18 DLX PartyBarge Hoover Reservoir - Columbus OH
Never put it on a scale but...
you are going to be very close to your 2k limit with a 19, trailer, outboard, and the usual 'stuff'. It may be a struggle to get up the ramp with a full ballast tank. You could probably get by if you are just launching and retrieving, but you may be uncomfortable out on the road.
Jun 2, 2004
3,670
I Think Your Going to be Over 2000#
You will likely be over the GVW as well when you load the crew and provisions into the car but as Henry said if your not planning long trips your going to be OK. If I remember right the water ballasted 19 is about 1500# empty the trailer will be around 700# then add the motor, gear, food, drinks, etc.
F
Frank Kilgore
Weight
Mine is the $7800 one for sale. An earlier post said the trailer weighed 700 pounds. That seems high, but I'm not sure. The trailer pulls very light to me (empty), but the problem may be when pulling out of the water. The water ballast will still be inside and won't drain until it start to rise out of the water. hat adds about 600 pounds. It may be on the upper limit of your vehicles tolerance, but you'll be hard pressed to find as "big" a boat this light. I wanted a small boat, but anything less than this has definite tenderness. I had a H 170 and was always worried about being knocked over. That is not a serious concern in H-19 and I think you'll be hard pressed to find one this size as stable and as light.
