hunter 18.5
Aug 22, 2013
15
hunter 18.5 Candlewood Lake
I have been slowly restoring my 18.5 and would like to find the OEM or very similar water tank (flexible I assume) to supply the galley pump. The hose from the pump leads to an area just forward of the mast and has a standard garden hose connection.
Will another 18.5 owner please look at their tank/pouch and let me know the brand/size/description, etc. Thank you.
-na -NA Anywhere USA
It has been a while. Can you take a photo of the galley unit and where it would go so I can suggest. Put on the smaller hunter sailboat forum where you will get more responses.
Aug 22, 2013
15
hunter 18.5 water "tank"
Dave, You're right, I'll posted my inquiry on the wrong site. I'll re-post it in the small boat section.
These photos show the "galley" - if you can call it that - with the pump; and the bilge space it front of the mast with the hose from the pump. The space available is apx. 2' by 1 1/2' by a foot deep in the center - as the bottom follows the contour of the hull with less depth on either side.
My guess is that there was the OEM water tank/bladder that held somewhere between 2 and 5 gallons with a male garden hose outlet which may have doubled as a filling inlet via another hose; or, just some large opening filler plate(?)
Please send me your email, again, as I cannot seem upload my jpeg photos from my computer onto this site.
Thanks much
