Hunter 18.5 mainsail batten lengths
Dec 19, 2022
2
Hunter 18.5 Lake Guntersville, AL
I recently bought a 1988 Hunter 18.5, it is missing a couple of the battens for the mainsail. Would anyone know the lengths of each batten?
Also, if anyone has knowledge they would like to share on the boat I am all ears!
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Welcome to the forum and congratulations on your new sailboat.
Determine the batten shape and purchase a couple longer than you need, lay the mainsail out, measure the length you need, cut them to fit and install a cap. Sources for battens and end caps are Sailrite Sail Hardware: Battens & End Clips (sailrite.com) or a windsurfing shop.
When dealing with a batten, I look to the sail and measure the pocket. Then I order the batten.
If you feel uncomfortable with that you could take it to a loft. Have them check the sail and make any repairs, then install the correct battens.
May 1, 2011
5,308
Pearson 37 Lusby MD
WM usually has generic battens that you can cut/trim to fit your sail. So would a sail loft.
