Hunter 170 cracked hull.
4
Hunter 170 Midlothian, VA
It looks like the Virginia winters are a little too hard for the good old Hunter 170. I have cracks in my hull and some soft spots on the deck. Some of the folks at my sail club were able to get their hulls replaced a few years ago when this started happening, but I think I am stuck with mine. I have seen directions for how to repair them, but can't find the materials they recommended. Any suggestions?
Mar 2, 2011
489
Compac 14 Charleston, SC
I found a similar product at an Ace Hardware store. It was a two part plastic weld epoxy with a 3000 psi strength rating. I used fiberglass woven cloth over one 3x3 hole and it worked well. I'll try to locate the exact name of the product and let you know.
Oct 8, 2009
134
Hunter 170 Lake Sammamish WA
What year is your 170? Mine is an '08. The first year I "chicken out" and put it in indoor heated storage for a $1000 bill. This past winter I decided to leave it out and we had a very cold winter with several days in the 'teens. When I uncovered it last month, I didn't find any damage. I did have it fully covered with a tarp that may have kept the hull a tad warmer than an uncovered boat.
Mar 2, 2011
489
My 170 was a 99' model, sold it last year. It's a great design except for the ACP skin. I'm glad to hear that Hunter has abandoned acp for good lod fiberglass.
Oct 8, 2009
134
Actually I was wondering about the age of JeffWingo's 170. From previous posts, it seems that the early models ('99 and a few model years on) are prone to cracking. I don't ever remember hearing about cracks in the later models. Mine is a '08 without problems.
tommym
Jul 14, 2011
5
Hunter 170 Port Sheldon
Four years ago my '97 model 170 had cracks on the upper curved flange amidships were the two hulls are glued together. It was a problem because rain water would get in the hull.
I had to pull off the rub rail to repair and reinforce the area. That was hard and the old rub rail was not in good shape because they superglue it on. I was told by Hunter to use Devcon Plastic Welder which I purchased at a local Holland Michigan hardware store. I don't know if the big boxes have it. I also used fiberglass to reinforce the area using this product even though I was told it was not necessary.
This product comes in a two tube dispenser that mixes the harder as you push the plunger. Then you mix it and apply it like puddy. After several coats and waiting at least 24h for each coat, I sanded and sprayed with white paint and I has worked well so far.
I bothered Hunter long enough and loud enough that they sent me a new rub rail at a reduced price. At least I think it was a good price. At least the boat is usable now without emptying the hull water every month.
Mar 2, 2011
489
Hunter ought to offer a reduced price replacement fiberglass hull for the hundreds of boats out there with no warranty left. I love the design but won't touch another ACP hull.
Jan 5, 2009
4
My hunter is a 2002. Fixing it is useless. More cracks will pop up. How can I contact hunter to complain?
Mar 2, 2011
489
The Hunter Marine website has contact info on it. Be sure to email them photos. I think there was a 5 year hull warranty on these acp boats. Even though it's out of warranty they might offer some help.
They quit making them with plastic last year and now use fiberglass.
Mar 2, 2011
489
I used a product I found at Ace Hardware called "Plastic Repair EPOXY" part number 17394 cost about $5.00 for a .85 oz syringe dispenser tube. It worked well and was easy to work into the cracks but is yellow and needed some paint afterwards.
Feb 19, 2008
472
Catalina 320 Tawas Bay Yacht Club
You have winter in Virginia?? You were being sarcastic, weren't you? Virginia is one of those places we Michigan folk dream about in February.
I think that ACP was a noble attempt at maintenance free boat design, but the cracking problems are too much.
My boat has lasted ten Michigan winters with only a few cracks, but in the last two years I have had a couple that have been more work than they are worth - I am thinking today that my sailing season might be over - it's boat repair season now!
John
