Hull trouble
160
Hunter 27_73-83 Harrington, Maine
Recently had delivered (by truck) a 1976 27 "project" boat. At some point during its journey the hulk cracked just aft of the shoal draft keel, enough to leak bildge water. I expect this was due to stress applied in the moving operation, as I don't believe it was there before. The driver called her a "tender" boat. Is this true? Has anyone else had serious cracks in this area? I assume I am looking at floor removal for adaquate reinforcment work. Any thoughts?
Jun 2, 2004
425
- - Sandusky Harbor Marina, Lake Erie
Cracks aft of the keel
Fiberglass if very susceptible to cumulative damage. So when we had Lady Lillie (our shoal draft '77 h27) surveyed after a hard keel strike three years ago, the surveyor found old cracks aft of the keel where he expected damage after such a strike. (Because the strike on the nose of the keel pushes it back and up.) He said that the more recent strike undoubtably made the earlier cracks deeper. Our insurance paid for the repair, which meant dropping the keel, grinding out a dishshaped space until the cracks were gone (they did not go all the way through the 7/8's inch layup), buidling the glass back up to the original thickness while tapering it onto the surrounding glass in the dish ground out, reseating the keel, and then coating the keel with bottom paint. The whole job cost $1,100 at a good yard in Cleveland, OH. You could probably manage the repair yourself, but you would need advice from someone else on dropping the keel on your own. I do have some questions: Can you see the cracks looking down at the bilge? If not, they may not be all the way through. (Although if the move stressed the keel, it probably made the cracks deeper.) Are you sure that the water comes from the cracks? There are lots of different sources of water in the bilge of a good old boat! Good luck fixing her up. You will have a great cruising boat when you are done! David Lady Lillie
Jun 28, 2004
30
- - Pensacola
Value
I may be violating protocol here, but I'm still reviewing the purchase of a '78 H27 for 7,000, and wondered what your project H27 fetched? Michael
Jun 5, 2004
160
Thanks Dave
David, That sounds about right, based on what Ive been reading in the fiberglass repair howto books. I think what happened is a combination of things, the last being the final transport. It's a pretty good crack, water from the bilge was leaking out of it, the boats on stands. I cant see from above due to the cabin floor, but I can feel a gap in the fiberglass rib that forms the aft support for the keel. The whole keel arragement is different than my H25, same year - not faired to the hull but some type of caulked or gasketed flange. I feel better knowing its repairable and Michael FYI, I paid 4 with a seiezed motor - on the plus side 3 weeks of soaking in marvel mystery oil solved that problem. Randy
Jun 28, 2004
30
- - Pensacola
Sounds like an excellent project sailboat
and a great value for your money. The H27 we were eyeing was a beautiful boat. I just wish I had the time to play. Did a lot of that over the years, but work has me working more than ever. Guess that's better than the alternative. Of course, winning the lottery would be nice, too. I'd rather sink the extra cash into a chute. Good luck, Randy, I'll keep an eye out for your entries and wishing you success! Michael
