hull to keel joint
2
Oday 39 oxford
Question:
An O'Day 39 hull #53 ,any info on hull to keel joint ,specificly the fwrd leading edge .Cracks radiating out at 45 deg. angles from the corners of the keel into the hull . Many thanks in advance
E.W. Clucas
Miles Creek Marine
Nov 3, 2010
564
Oday 39 Lake mills WI
I have hull #54 with the exact same cracks. I'll be taking the shower pan up next year and beefing things up.
Nov 3, 2010
564
Just had a boat yard look at the cracks. Certainly strucktual was the responce but they do not plan on gaining access on the inside. They will do everything on the outside. I'll post the layup when the work is done.
