Hull Thickness
Feb 26, 2010
16
Hunter 34 Punta Gorda
I am considering installing a new chartplotter with in-hull transducer, however I can't seem to find out if my Hunter 410 has a solid hull for the transducer to work properly. Your input will be appreciated
Nov 8, 2007
1,596
Hull is solid
I'm not aware of any Hunter hulls that are laminated below the water line.
Of course, local delamination is possible due to initial quality, or later wear issues. You can work around this, however by trying out the transducer at the location(s) you may place it.
I have not heard of members setting up to shoot through the hull and having a problem after following this approach.
