A
Aaron
I am looking at buying a cat 22 in need of some restoration. The hull appears to be in fine condition with 2 possible problems. The first is the way the boat was stored. It was sitting on 4 pads in a "V" shape (similar to the rails on a trailer). The current owner let his kids play on the boat and they knocked it off the front two pads. This caused the boat to rest most of the weight on the middle of the hull at two points. When I looked at the boat, I noticed that it had some very slight bend inwards at these places. When the baot was put back on all four pads the bend went away. My question is: Does this bend that is no longer there affect the strenght of the hull? And if so, are there anyways I could test the hull strength? The second question I have is this: There are two holes that were cut in the bottom for viewing ports. I don't want or need these, can I repair this? The holes are about 8 inches in diameter. Thanks for all the help.
