HP per ton
Generally - the recomendation is 3-5 HP per ton. For example, the J22 I sail does fine with 4-5 HP, a Catalina 25 generally needs 8-10HP, a 27 will want 12-20. Remember that displacement as given by many (most?) mfrs is (unfortunatly) light boat weight - so don't forget to add crew, fuel, fluids and stuff. A boat that is big for its weight will have windage issues, also if you need to fight big wind and current, you will want want power on the high side of the above range.The usual formula for hull speed is 1.34 * square root of waterline length (DWL). It is not actually a hard limit - just an area of a knee in a curve of power vs speed that represents greatly increasing difficulty to get more speed.
