Yes you can go faster!
Hull speed a result of the hydrodynamic forces at work. Like previous posts, this theoretical speed is determined by the (length of the water line)cubed, times 1.34.As a displacement hull goes through the water it creates a pressure wave. You can see this wave on any boat moving though the water. The faster the boat goes the longer the wave gets. Hull speed is reached when the wave (the high sides) becomes the same length as the boat. When you are going slower than hull speed the boat is going down the backside of the wave (down hill), requiring little power.To go faster than hull speed takes power, lots of power. As the wave gets longer, the boat must try and climb the front part of the wave. It’s like going up hill. And faster you go the steeper the hill, but if you add enough power you can go faster.Run down wind, put up a huge spinnaker, adding tons of power and you can go considerably faster than hull speed.Hope this helpsBobC-36
