Hull Speed Explained!?
Hull Speed;When a boat goes through the water, it creates two waves. The first is the bow wave (self explanitory.) The second is the "quarter" wave. If you look over the side while your boat moving slowly, you will see that imediately behind the bow wave, the water dips down, like a wave in reverse. And just behind this is another wave, called the quarter wave. As the boat speeds up the quarter wave moves further and further back, with respect to the boat. Finally, the boat reaches a speed such that the quarter wave is formed by the stern. So, this means that there is a high point in the water at the front of the boat and a high point in the water at the back of the boat, with a low point in the middle, and everything is balanced. But, in order to go faster, the boat must start to also go "uphill', since in going faster the quarter wave will be left behind. The point of balance, or equalibrium, for any given boat, is the hull speed. Anything faster than that means the hull is starting to lift out of the water, or "plane". The hull speed, therefore, is a function of the boat's length and the specific gravity of the water. In practical terms, rthe following formula is used. Square root of waterline length of boat (in feet) times 1.34 = hull speed (in knots).Example: If you have a 28 or 29 foot boat, the waterline length is around 25 feet. Square root of 25 = 5 5 times 1.34 = 6.7 knotsThis is all very theoretical, but I hope it helps, a little.
